My AR Build
I have the primary arms micro dot...more or less the same thing as the bushnell trs-25.
Works well for the price range, haven't had and zero issues even after taking it on/off.
havent done anything else to the gun, still havent shot it either, been too busy. hopefully this weekend though. been buying ammo and mags instead upgrading anything.
i'm going to build a AR10 next using an 80% lower. found a good deal on one for $150. i'll be using this to do it.
My AR Build
My AR Build
after a quick google search, it appears it's a Enco GL-30B from 78-79. it was my wifes grandpas. he was an engineer of some sort. has an old shop with a bunch of cool stuff in it. i get my pick of everything next time we go up.
Belt driven, variable speed drill press... That's cool! :icon_thumby:
i know man, first time i saw it i started scheming about how i could finagle it into my possession. finally worked out. only thing is, i cant find the top cover, i dont know what happened to it. maybe it's in the shop somewhere.
4.0B2 updated his AR page, so I decided to update mine as well.
i did a shitty job on the first duracoat paintjob i did, i didnt like the color either. so i took the rifle compeltely apart, stripped everything and painted it again with magpul FDE duracoat. much better job this time. it's not flaking off anywhere, yet lol.
i've put 70 rounds through it so far with all sorts of different ammo and it hasnt failed to fire or not cycled. so far so good.
i was also a little worried about it blowing up. i never had the head space checked by a gunsmith. i read on a bunch of forums about whether i needed to or not. it's like a chevy vs ford argument. 50% say you should and 50% say you dont.
so what i did was take the assembled upper off. took about the BCG, put a live round in the chamber and then put the BCG back in. you want the back of the BCG to be flush with the back of the upper receiver. you dont want it sticking out, or going too far in. mine was flush, so i said F it and shot it anyhow.
so what i've gathered is that if you used ALL mil-spec, brand new parts, you should NOT have an issue with headspace. when the barrel is made, they check the headspace when the barrel extension is pressed in. which makes sense if you think about it. you'd have to wayyyy overtighten the barrel nut in order to create too much headspace. or have a barrel manufacturer that let one slip out the door being wrong.
next up is a red dot. i've narrowed it down to the primary arms red dot or the lucid h7 above. too many choices. irons work fine for now though. i also put out an xmas present request for a new muzzle brake. the A2 sucks IMO.
My AR Build
update on the rifle
got a scope for it finally, it's a Weaver Kapsa 1.5-6x, going to shoot it/zero it for the first time today. we'll see how it works. i plan on using it for deer hunting only, still planning on some sort of red dot
My AR Build
My AR Build
got some magpul grips at the last gun show, i really like them. good grip and it makes the rail fit my big ass hands a lot better.
My AR Build
got a new muzzle device too. it's a YHM 5C2 (i think). it's a flash suppressor and a compensator according to them. testing it out later today.
My AR Build
mostly just been buying ammo for it. found a few good deals at the last gun show. put about 250 rounds through it, so far so good. no failures or explosions, hope it stays that way.
