My 88 D21
Ranger850
Doesn't get Sarcasm . . .
Tallahassee Florida
Stock 2"
Stock
Doing things wrong, until I get it right.
This is the 88 Nissan Hard Body "D21"
37136
37137
This is the day I first parked it in the yard. It was worse for ware. At first glance, It was ugly to say the least. When you got up close, it was even uglier. The Hood and PS fender had obviously been replaced, so it has been wrecked, :poop:, The wheels were just disgusting, and the interior was horrendous.
37138
The door panels were replaced with wood paneling, the bench seat had a couple of pillows stuffed into the Driver's side, for support. and the dash is ….. I cant find words for the dash.
As far as the Drive train, it wasn't too bad. It started up every time, no problem, and it drove fine. Leaked a little oil I thought, no problem still, It is 30 + years old. But the rear breaks were leaking.
37139
One of the first thing I had to do was ditch the bench for some buckets, and find some door panels for this thing.
37140
And then, on to the real stuff,
37141
replaced the old wheel cylinders
and did a rear break job.
37142
Now that my stopping juice wasn't leaking out, I jumped into some cosmetic stuff, WHEELS.
37143
^^This is what they looked like when I got them.
So, I stripped them down to bare metal. There was this plastic clear stuff over the wheel, I chose to use a "waffle wheel" to get it done. That and a good pressure wash session netted decent results.
37144
37145
Using the DODGE wheels as inspiration...
37146
I did this...
37147
37148
It's very subtle, especially with 15" wheels, but the face is black and the backside is Gold.
And now the Truck looks like this
37149
The Door handles, were working, but that's it. The DS was dangling and the PS was a plastic POS that was just going to fail at any time. So I found a guy on InfamousNissan.com wanting to get rid of some metal, chrome ones for the $$ of shipping.
37150
The emissions on this little truck was a joke, so I removed all of it from the engine bay.
37151
The top shot is the fender where all the emissions stuff was jammed in there.
The engine bay now needed a good cleaning, so I could try to figure out where the oil was coming from.
37152
I did the undercarriage too
37153
Time for new plugs & wires, and a Valve Cover Gasket.
37154
Look what I found, the oil leak?
37155
The plugs, :sick:
37159
New Plugs in, new wires on, and VCG replaced. I also painted a few pieces while they were out.
Before
37156
After
37157
37158
Nice job bringing a truck back from the "grave".
Never have owned a Nissan pick up, but used to race SCCA in a Datsun 510.
Have had same era Toyo trucks. Back then they were solid, dependable little trucks, and with routine maintenance would last forever.
Luck with your project.
Grumpaw
Now that she was running smoother, I jumped to the inside for some trim pieces.
37160
37161
DS pillar
37163
PS Pillar
37164
Mirror Trim pieces
37165
37166
The gray material I used is called Microfiber. I got it off of an abandoned couch lol
The mirrors were a sad subject too. DS was fine, but the PS was not. It had a huge, oversized convex bubble bolted to the mirror housing.
37167
Here they are, already off of the truck.
I found a nice Xterra at the JY that looked like the Mirrors would fit my HB, so I snagged them.
37168
37169
But before they could go on, I had to do some slight mods.
1st, I had to cut out these little tabs.
37170
37171
Then I had to smooth that out, using a grinder to open it up a bit more.
Then I did this
37172
37173
This is a little rubber boot that came on the Xterra Mirrors that were NOT on my HB. I removed that part instead of making the hole larger.
37174
prepped and ready for paint.
Drivers side done, nice fit
37175
D21 vs Xterra
37178
And here is a Left&right shot
37179
My next big project is a brake upgrade. I ordered all V6 components, ( slightly bigger and thicker rotors ) and will be putting those on soon, along with the leaf spring bushings. stay tuned...
Nice work so far. The body looks to have held up pretty well. I love the slide bolt latch for the driver's door. Classic Mr Bean mod there. I'm assuming you'll be addressing that at some point.
