- Aug 19, 2001
- So. Calif (SFV)
- 2.9 V6
- Tire Size
- 35x12.50R15
Probably a dumb time to ask this.
Ummm... yeah
That could easily explain why your patterns are so all over the place.
You got a Harbor freight near you? A press is normally priced at $149 right now. You need one (and a bearing splitter if you don't have that either). Watch for sales, that press I think is a frequent sale item at around $99-129.
Edit: You could also try locating a GOOD bearing and carefully hone it out for a setup bearing, although if you have the proper tools, an unmodified bearing is very easy to take off & put on (the pattern could still change slightly when you swap to the regular bearing anyway, you'll still need the press & splitter if this happens)
.it is the way to go if you don't have a bearing puller and theres nothing wrong with doing so
