Nathan T
- Mar 25, 2009
Hi, I used to be a member on this forum under a similar name but for some reason it can't find my account (I had joined in about 2002-2003), but anyway...
For some reason my truck is sputtering when I first start it up. It does it worse when it's a warm/hot start. It used to only do it when it was a warm or hot start, but now it's doing it when it's totally cold too. I've always kept up with the maintenance on it. It has new plugs and wires in it. I replaced the MAF sensor last summer along with the TPS. It almost acts like a carbureted engine that's loaded up or something. I read another post on here saying that the alternator could possibly be the cause (leaking AC current into the wiring)? My alternator has some issues, the bearings are dry in it. I replaced it a couple years ago and got the 140 AMP? Explorer alternator for it from Advance Auto and it's always made bearing noise. So maybe it has more issues than I'm aware of? The fuel filter isn't that old either. It also has a new air filter in it.
Is there anything else that's known to cause this? It seems like when the MAF sensor went bad it sort of ran like this, but WAY WAY worse. My check engine light never comes on because of this. Any ideas?
Thanks.
Thanks.
