My 1998 Mazda B3000 4x4
Nice truck!
I have a soft spot for those late 90's Mazdas.
My daily is currently a '99 B series, 2WD manual with 189k on the 4cyl motor. I've always wished it was a 4wd though!
I do love this truck! I'm hoping that it will last me a long time if I can take good care of it
Welp, I got the transmission and everything put together and all buttoned up, and now the shifter is stuck and the clutch pedal has no pressure. Is it possible that the slave cylinder I purchased was faulty from the factory? I wouldn't think the system needed to be bled again as all I did was remove the quick detach when I did the clutch. The shifter will not budge whatsoever and whether the car is on or off makes no difference.
Nice truck!
I have a soft spot for those late 90's Mazdas - wrote an essay about by best essay writing websites help . My daily is currently a '99 B series, 2WD manual with 189k on the 4cyl motor. I've always wished it was a 4wd though!
when you remove the shift motor you just see the shaft that you rotate to shift it, but if rotating the shaft does not actually shift it, that means something internally is wrong.
when you remove the shift motor you just see the shaft that you rotate to shift it, but if rotating the shaft does not actually shift it, that means something internally is wrong. I advise you to take a look at the online service published here, which will help you deal with the problem of written homework. It will help you improve your college performance.
Thanks a lot for help!
@Sean's84 sounds like a twin to my '99 almost exactly the same miles. I also wished for 4x4 so I have the '97 also now which rocks.
