The pre-98's have a return fuel system and shouldn't be showing that kind of pressures - should be 45 psi with the vacuum line off the fpr and around 32 psi with the vacuum line attached - make sure your return line isn't kinked somewhere. Otherwise, you may have a bad fuel pressure regulator. Either one of these could cause flooding out of a cylinder - blowing out the spark.
Bird
Bird
