MPG in 4.0 xcabs w/ 33s?
krazykracker
Lakeland,Florida
im just installed a 4in lift & would like to put 33s on but dont want to kill my MPGs,i also dont have the $ or the 35s to regear to 5.13s.
mine has 3.73s,4.0,5spd,xcab
what are you guy's MPGs w/ xcab rangers w/ the 4.0 5spd
Little different beast, but my 4.0L SOHC 5-speed with 32s and 4.10s can get up to 20MPG if I'm being easy on it and using hills to my advantage. I can easily suck that down to 15MPG when in town and hammerin down.
My 91 explorer with 6inch lift, 3:73 gears and 33's does around twenty on the highway but that's imperial gallons. I drive easy though.
I have the 2000 xlt extended cab off road sport and get 22 hwy and 17 city running factory 245/70/16s with 4.10gears and 8.8rear with a detroit locker. I am a stop light racer, so in town I like to crank it pretty good and let the cherry bomb do its job and warn walkers to get off of the sidewalks! LOL
Ok, my truck is a 1987 Supercab with a transplanted 1993 4.0 engine
Mazda Trans 13-54 T-case and 1997 Dana35 front axle and of course a Gen3 8.8" axle out back with 4.10 gears
My truck has a 1" body lift and around another inch of suspension lift (washers in the front, thicker factory blocks and explorer springs in the back)
Running my 235/75-15 BFG A/T's at 50psi I JUST last week while towing a 1992 Ranger 2wd std cab (3.0 5sp) with a 4.0 engine and an 8.8" axle and another 500# of assorted flotsam & jetsum in the bed I got 15.409mpg
on the eastbound return trip from South Bend, Indiana to my house
4 miles north of the intersection of US209 and I476
On tht trip I only shifted out of 5th for a couple hills and then mostly because I didn't want to slow down enough to stay in the right lane behind a slow truck and I NEVER turned off the A/C.
I got 18-something on the trip out, but wasn't really paying attention
because we made side trips to Summit in Akron, OH and to Cabela's in Dundee Michigan going outbound.
I can't really take credit for the mileage, because I was being lazy...
I spent so much effort retrofitting cruise control to the truck
when I rebuilt everything two years ago that I decided to actually
USE the cruise control, so for most of the trip "George" was manning
the throttle I was just choosing what lane to cruise in...
Personally I KNOW I can get better mileage driving manually
(take runnig shots at the hills, etc...)
with 33's I'd look to getting 14-15 if everything is working right...
I have gotten 21 to almost 22 with the truck on several occasions
and I'm looking to regear (3.73's) to improve it's highway cruise mileage
(it'll also make 4th a bit more useful on the highway)
AD
Mine is a stock 2004 4.0 ext cab with 245/75r16 toyos. I never got 20. My best was a 18.5 mpg tank on my way to Olathe, KS. Owned the rattle box since new.
I used to have a exploader 4.0 with 33's and 3.73s and i got 5mpg.:headbang: True enough this was never on a road and i was always holdin er.
my ranger is a 99 reg cab with 4.0 5spd with a limited slip 3.73 rear,and i have 265x75r15 tires on it and i get bout 17- 18 with it. with the stock 235 tires on it i got bout 18-20. so i would plan on 15-16 with 33s.
I range from 17-22mpg in the Explorer/5 speed.
About what I get as well (17-21 or so. Best tank was 25, but I had a good tailwind, and have never repeated that amount of mileage since) Ranger 4.0L/stick/4.10/33s
wow. i get 10 in the city. i need to fix that
4.10'S 4X4 EXT CAB 4.0 SOHC AND AND AUTO MY BEST EVER WAS 20MPG.. ITS TOUGH TO ATTAIN.
sorry bout the caps!
oh and im running 32x11.5's BFG's
91 s cab 3.73 ,4.0 5spd winch & w bumper 50% worn trXus m/t's my highway best 17.5 mpg (US Gallons) in town 13.2 mpg (US) worst with lots of 4 lo ( cause off road that is where you will be ! ) 9.4 mpg (US) .
You may have to trim a bit:yahoo:
