moving coil bucket
Hey has anyone moved thier coil buckets? any advice.....
Do you want to move them up or out?
Both have been done before. Search.
I am going to move them down and loose the 1" spacer on the bottom when i cut off the stock shock mounts and use a shock mount brackets for an f250. What does moving them outward do for me?
he is talking about moving them farther from the frame if you are doing a SAS with a full width axle
That's an awful lot of work when it would be easier to purchase a longer spring....
Longer springs will lend themselves to more suspension movement, thus requiring the longer shocks and f-250 towers.
x2. Don't move them down. Get longer springs instead.
There's also nothing wrong with keeping the spacers...
