Motorcraft vs. Vavoline Max Life
ranger1999xlt
Iowa
I have been using Vavoline Max Life 75,000 miles Full Synthetic 5w-30 in my 98 Ranger 2.5L with 83,000 miles. I was wondering if motorcraft 5w-30 would be better just because that it was the book recomeneds. What would you use. Motorcraft or Vavoline Max Life? Thanks!
I have never looked at the additives in Valvoline Max life but since it is for high mileage vehicles I'm guessing it probably has some additive that swells the gaskets/seals to "increase the life of your engine" which would only be a bandaid instead of fixing the problem. But like I said I have not looked in to it so I could be completely wrong about this. All I know is I wouldnt use it I will always use Mobil one synthetic, so out of the two I would have to recommend the motorcraft oil before I would recommend valvoline high mileage.
EDIT: I also found this http://www.syntheticwarehouse.com/high_mileage_oils.htm when searching about high mileage oil
i run valvoline max life conventional and havent had any problems with it.
the truth is, oil is oil. as long as it is ASE stamped and of the proper grade, not much else matters. it just makes me feel better to run "high mileage" oil.....ahh the miracles of advertising :blush:
I never saw anything wrong with the motorcraft oil. in fact I prefer it
when I bought my 87 ranger it had over 200,000 miles on it, I always ran motorcraft 15w40 and a can of 4 cylinder restore, and the truck still ran like a champ and passed inspection, and did not smoke the day I sold it with over 300,000 on the original motor.
I would not recommend putting 15w40 in a motor as new as yours though.
also I would not recommend any synthetic oil ever.
I bought a 2000 ranger 4.0 brand new back in the day, and on the first oil change I put full synthetic pennzoil 5w30, and it had a slight tap that never went away ever since. it didn't have it before but always had it after no matter what oil I ran even when I tried putting in synthetic blend, and even regular motorcraft 5w30.
I can't say I had any excessive engine wear or anything, I just was pissed off about the tap... not to mention after experimenting with different oils over the years, I don't see anything wrong with regular oil, especially if you are changing it every 3000 miles.
