motor swap
captping
Will a 3.0 motor from a 93 explorer fit a 94 ranger 3.0?
As long as its a 3.0 short block like your ranger comes stock with you can use it, even if its older itll bolt right up with no Mods, now the sensors maybe different with explorers and Rangers, but im putting a 93 Ranger in my 95 Ranger and so far everything perfect, the only thing im not sure about are some of the sensors...Hope that helps....:headbang:
the explorers didnt come with anything other than a 4.0 in 1993. unless the engine and transmission were swapped (not likely), its not a 3.0.
