jcwilliams
- Jan 27, 2014
Not sure if right area for this but I had a 1999 ranger 3.0 flex fuel engine hooked to a manual trans that I needed to stick in a 1998 ranger that had a 3.0 non flex fuel automatic trans in it.
All went well with the swap everything works as it should runs fine other than I have both banks running rich.
Would the computer be the issue in this case?
I have a exhaust leak before rear cat in front of rear o2 sensor (single pipe out ) maybe that's the issue?
Fuel pressure regulator?
Thanks in advance.
James
Thanks in advance.
James
