Motor Mount Holes
rednine4
I have the Motor mounts from the advanced adapters conversion kit. I bought these used and I dont have any instructions. I have heard that new holes will have to be drilled for these. Can someone please provide more details. A sketch or dimensions? Possibly a copy of the instructions?
Good luck with trying to use someone elses dimensions for drilling holes. Put the engine and transmission in place, get it where you want it to be, then mark and drill where the holes need to be. Do not try to use the frame rails for dimensions, they're not centered under the body and aren't straight enough to use them as reference points. Center the motor between the fenders, level the carb pad (or lower EFI intake to upper flange) aim the transmission tail toward the rearend pinion and mark where the holes need to be for the mounts (obviously the mounts need to also be present on the engine block as well)
I will have to double check my part numbers on my mounts... They look alot like the first ones you listed.
