its not really a huge deal. but about every month i need to add a quart of oil. what would be a few main causes i could look into
That makes sense I would imagine the plugs on the affected cylinders would show signs of oil also and the compression would be slightly higher also. Once you get the oil thing fixed you may need to change the cat/s they are likely toast.could be the lower intake gasket mine burned the same amount because of that. i hear its a common problem with the 93 and 94
