- Jan 22, 2009
- La Grande, OR
- Automatic
what is the best bang for buck on getting more power, i was thinking of regearing i already have a cat back exhaust, any ideas
air intake, then chip, gears don't make power and it hurts highway MPG. pm me for an air intake
curt
gears dont make power, they multiply torque...which is percieved as faster acceleration (more power).
running your engine near its peak torque figure will provide the highest fuel economy figures. for the 4.0 thats 3,000 RPM. depending on your current gear ratio and tire size, you could see an INCREASE in highway fuel economy with a deeper gear.
stay away from so called "cold intake" kits. your factory intake is already cold air and already flows more than your engine can draw. id give you the same warning for exhaust systems, but you already have one. e-fans also offer no advantage over a properly functioning clutch fan.
being that your truck is OBDII, i would look into a tuner to modify the PCM's programming.
I certainly wouldn't cruise around in a 4.0 at 3000RPMs, SOHC or not, no way it will get it's best economy there. 4.0s seem to like 2100-2400 the best.gears dont make power, they multiply torque...which is percieved as faster acceleration (more power).
