Frequently Asked Questions:
Q. Do the blades inside spin or rotate at all ?
A. Yes, the blades do spin. They spin at up to 65,000 RPM.
Q. Is this an Electric Supercharger ?
A. No, this is not.
Q. How is the unit powered ?
A. The unit uses your vehicles intake system to power its blades to spin at up to 65,000 RPM. The patented angular blades create greater efficiency in your combustion process. These conditions create better performance at higher gears and increase fuel mileage at lower gears.
Q. Does a Filter Fit inside it ?
A. While our unit is designed to work in conjunction with your current filtration system. The unit does not come with a filter.
Q. Will this work to give me more HP on a Turbo Engine ?
A. While our unit was designed for regularly aspirated engines, we have had great success with our clients that have bought the item for their turbo vehicle. They have reported increases in both HP and Fuel Mileage.
Q. Does this unit increase the pressure in the inlet manifold ?
A. This unit does not increase the pressure in your inlet manifold. It increases the efficiency of your airflow into your combustion chamber. This increased efficiency betters your performance and improves your mileage.
Q. Will this work on carbureted engines ?
A. Our unit is designed for the modern combination air intake / fuel injection systems. We have had many clients, however, adapt it to their carbureted engines.
Q. Does this unit come with fitting instructions including diagrams ?
A. The unit does come with detailed instructions on the installation process.
Q. Is your system compatible with aftermarket intakes or induction systems ?
A. Please contact us with details on any aftermarket systems and include diameter and depth
measurements of the tubing on your aftermarket system.
Q. Will this fit an oval shaped intake system ?
A. No, this unit will not fit oval shaped intake systems.
Q. Does this work on diesel engines ?
A. Yes, this will work on diesel engines.
