- Aug 26, 2021
- Iowa
- 2022?
- 2.3 EcoBoost
- Automatic
Yup...old school reliability is definitely a thing.....
.kingpin 60...check.
Captain cave pig multi fuel engine..that runs at any angle...and can run with no electrical at all....check.
More then one way to start engine....check.
4l80.......this ..is the previously undisputed heavyweight king of transmissions.....even stronger then any of the manuals...and I still manage to break them with dumb as a hammer 120 hp engine.....check.
In a failed transmission computer situation I can manually shift it still.....so redundancy to captain cave pig level....check.
That is what I drive.....no AC....no radio....manual windows and t case and lockouts......when I am not in my shop truck.....
I can and do fearlessly run 44 inch tires on it....or 32s... Sometimes in the same day.
And the new bronco will whoop it's ass in modern off roading.
Sure...the bronco won't haul or hold what my pick up or a 78 bronco does...but it will definitely out perform it off road.
As to off roading.....your dreaming...
What we do now....those back in the day can only dream about....because it would be fantasy. I can drive over 5 foot tall obstacles...
A 79 bronco is awesome....very capable...but will not go where a modern bronco will...unless the modern bronco is dragging it.
The 351 m is very complicated to keep alive.... It is very buildable and capable but you have to know what the fawk you are doing
And it requires propane or fuel injection to even think about venturing where I go ...and a very expensive or thought out oiling system. The timing of the journals and sump are unforgiving of starvation.
I know this.....I have built or assisted builds that can run the jungle or the tank trap and learned from those that do it.
Not opinion. It is what it is.
Mr Bobby, I believe we should plan a YouTube video to showcase the eras! Can you wait about 3 mos (minimum), Rocko isn’t estimated to be delivered until 5/31.
