moog vs. napa adjustable camber bushings
ranger227
I recently lowered another 2" with drop coils and I did replace the camber bushing with a moog caster camber bushing (K80109). Took it to two alignment places and still couldn't get it align. Left camber is -3.4 degrees and right camber -3.2 degrees off. My truck has 3" chasis tech I-beams and lowered 7" in the back. Please help me out....
Did you get a sheet explaining how to use the bushings when you bought them?
I have some of the Napa ones that go to either 3.5 degrees, or 4 degrees... I can't remember; however, the important thing is that I have the sheet that explains how to align the letters up to give a certain amount of camber and caster adjustment.
yes they used to sheet that came with the bushings. I think I figured it out. The 2" springs I used was spring tech(ebay purchase) and it is very scrawny compared to any other springs I have dealt with. I think it is lowering it too much bc it is weaker. I am going to order bell tech 2" springs and see if that helps. Or do I have the wrong camber bushings? Thoughts?
