moddbox supercharger kit troubles
The only issue I had with the Moddbox kit was that the fuel pump died not long after I got it. So, I got to drop the gas tank while nearly full - what fun that was! Unless you plan to run it hard at high rpm, or put a small pulley on the blower, the stock injectors are fine.
should it happen again it is easier to lift the bed than it is to drop the tank
