I overlooked something from earlier. Porting your heads,a cam with a lot of rise and duration, and larger valves will actually work AGAINST the turbo. The turbo will be trying to fill up the combustion chamber with a lot of force and that same force will find its way out through the exhaust valve gone and wasted(in that moment of time when both valves are open at the same time). Larger valves and and higher lift only adds to that problem. So usually the stock configurations that most motors have will be just fine. Naturally aspirated and forced induction engines have two entirely different approaches to making horsepower. So what may work for one may not work for the other.
I overlooked something from earlier. Porting your heads......and larger valves will actually work AGAINST the turbo...
he never said a turbo motor he said boosted, thus my post
