Missing
Old Steve
Earth
A week ago the engine ran just fine, started it up yesterday and had major engine miss and a shutter when I gave it some gas. It has around 95000 miles. Could a PCV valve cause this? If not any ideas?
Thanks.
Old Steve
Check the codes and let us know what numbers come up.
No codes. The engine miss is not as bad after the engine warms up. Any ideas?
From description its most likely a spark plug is bad, it just happens, could be a wire but plug is more likely
4.0ls eat spark plugs up
Motorcraft or AC are best brands to use, NGK a close 3rd
Big gap, 0.054
Regular copper/nickle or DOUBLE Platinum, single coating is a waste of money with Coil Pack systems
I'll give that a try...thanks for your help.
