basilfaulty
- Jan 25, 2011
- Automatic
I have a 99 3.0 with what seeems to be a miss @ cruising speed. You can be driving along fine and hit a hill and it develops a miss under load. If you accelerate it goes away or if you shut off the OD it goes away. No CEL, almost like a lean miss but I can't find a vacuum leak anywhere. Sometimes it does shudder a little bit just off idle if you take off on a hill and sometimes it seems like it has a miss when you first start it cold but it goes away in a minute. What gives? TPS? coil breaking down?
