Miss After Tun Up
frank burak
NORTHERN IL.
I Have Replaced My Plugs With E-3 Type Plug And New 8mm Wires And Have Developed A Miss Any Help
Most guys on here reccomend an OEM plug for best performance. I use Motorcraft in mine and they work great!
those e3s are a waste, go with motorcraft. check make sure all wires are in correct location... make sure you didnt crack any spark plugs.... make sure all wires are fully on.
yeah motorcraft or good ole autolite copper core plugs seem to run the best. if you think about it electricity always takes the shortest route so unless your plug is gapped perfectly at all three points then its going to spark off the closest point.
Yeh run the motorcrafts. Make sure they are gapped properly as well!
not much sense in telling you what i think. everybody above me has already said it.
