Misfire / lean run
K Thompson
Highland Village TX.
3.0 V6
I have a 2003 Ranger 3.0l 5 sp stick. Love my little truck. Bought it 18 mo. ago after my Tundra was totaled. Anyway It had 152K miles when I bought it, and now has 165K. Has had new Motorcraft wires Autolite plugs SMP coil Motorcraft TPS SMP PCV valve and various vacuum hoses that were cracked. It has been running great until yesterday it suddenly acted like a plug wire came off. Soon got the CEL. Took it home scanner reports misfire on cylinder 2 and lean bank 1. Ok replaced plug and wire on #2. Ran the same. On the way home from the parts store, it suddenly began running correctly again (for about 1/8 mile) then back to missing again. It now only gives a lean code (P0171). I have a shop made smoke machine that uses regulated shop air to find vacuum leaks and could not find one. I also sprayed a can of carb spray around the lines and plenum with no increase in revs. The coil will make a blue hot spark about 1" long on each coil port. Would love to hear where you guys think I should go from here!!
Thanks again
The Boltman (Keith)
Injector plugging up or not opening is my guess
Lean code means upstream O2 sensor is seeing higher Oxygen in the exhaust on that side of the engine, Bank 1 is passenger side
Cylinder 2 is on passenger side of engine
What happens when a cylinder Fires?
The fuel is burned up with the Oxygen
So when a cylinder Misfires............................
No Oxygen is burned up, and that Oxygen goes out to O2 sensor, and higher oxygen levels and then Lean Code
So Lean code is not symptom is if there is a Misfire, Lean code is the result of a Misfire, so until Misfire is diagnosed ignore Lean code
Test compression on 1, 2 and 3, or all 6 cylinders, even better
Take burnt exhaust valve off the menu, or find out it is the issue
If you have an intermittent misfire at idle, spray fuel into the engine while its idling, if misfire goes away then it could be faulty injector, if not then it isn't
Thanks to Rusty and Ron for taking the time to help. I replaced #2 injector and she runs great again.
You all have a great holiday season and prosperous new year!!
