BroncoRick
- Aug 10, 2007
Found some parts that have been sitting 15 years in boxes, I'm sure someone can use them. Bronco II was t-boned and I pulled parts before it was scrapped. Probably threw more parts away over the years. Cost plus shipping or make me an offer. I will have to box up and weigh parts to get a quote for shipping.
2.9 fuel rail - needs cleaned up and painted
$25
2.9 distributor with new hall sensor and oring at the time. Had new wires and "BEST" cap with the copper lugs. No ignition module! Also comes with 6 Motorcraft AWSF 42C plugs new in boxes
$50
Valve covers with bolts and load spreaders - not bent up but need cleaned and repainted.
$35
ECM from 89 Bronco II 2.9, auto, 4wd
$50
A4LD shift improver kit - also comes with ATSG manual and update manual
$50
2 thermostat housings free of cracks
$25
3 D28 manual hubs and 4 spindles. I'm pretty sure all the parts to change auto hubs over are also in the box. If you need pieces parts it will be cheaper to ship what you need. Box is heavy!
$75
58mm throttle body from an 86 2.9. The inlet was smoothed and radiused on a lathe. Needs cleaned up
$75
Last but not least, set of JBA shorty headers. They will need cleaned back up and painted or ceramic coated. I would blast them but blasting compressor is down needing parts that I can't order right now.
$200
$25
$50
$35
$50
$50
$25
$75
$75
$200
