- Oct 25, 2015
- Bismarck ND
- 4.0 V6
- Total Lift
- 4"
- Tire Size
- 32's
- My credo
- Break. Upgrade. Repeat.
8.8 from a ~2000 Explorer and a G2 mini-spool.
I'm putting in a mini spool. I thought it would be easier, but nothing fits together! I had to grind the c-clips to get them to fit in the grooves, then I had to grind the mini spool blocks because they were too wide to fit between the axle shafts. Now the cross pin won't slide back in easily. Should I grind that too? Should I coerce it with a hammer?
Is this much difficulty normal? What am I doing wrong?
I thought this would be easy, but I need help!
Thanks.
- Joe
Thanks.
- Joe
