Jim Oaks
Just some guy with a website
Founder / Site Owner
Administrator
💻 TRS Socials
TRS 25th Anniversary
TRS Banner 2012-2015
GMRS Radio License
- Aug 2, 2000
- Age
- 58
- Nocona
- State - Country
- TX - USA
- Other
- 2005 Jaguar XJ8
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 2.3L EcoBoost
- Automatic
- Total Lift
- 3.5-inches
- Tire Size
- 295/70/17
This link will give you different performance/speed ratings for different winches:
http://www.trsfabandoffroad.com/products/winch_performance_comparisons.htm
at a 6,000lb load, my Warn XD9000i will pull at 8.67ft/min. A Warn M8000 will pull at 9.79ft/min, the MM PE8000 will pull 6 ft/min and a MM SX9.5 will pull at 12.8 ft/min.
When you compare line speeds, look at the speeds with the same loads. Warn M8000 is rated real fast with 0 load, but only 3.79 ft/min faster than MM under load.
It would take the MM PE8000 2.04 minutes to winch 6,000lbs 20ft. It would take a MM PE8000 3.33 minutes to do the same. A MM SX9.5 could knock it down to 1.56 minutes.
