mazda wheels?
Guys found some 2001 mazda B2300 steel wheels 15x6JJ (whtever the JJ is) are these compatible with my 1995 ranger 2wd std cab on an upgrade from 14" will be putting a little meatier tire on them as well....need a response ASAP. What is the backspacing on these wheels i have searched and cant find anything!
they should fit just fine, i think the offset is a +14, not sure what that comes out to in backspace but it will be about the same as your 14s. make sure you check the center bore though, they changed the size but im not sure what year
Ok I bought the 01 Mazda steelies, anticipating putting a Goodyear Wrangler Radial from Wal-mart on it for 65 each (235/75R15). This is a stock (for now) height Ranger 2WD XLT Std Cab, can I expect fitting/rub problems? Measured out side diameter of wheel its 29"
Speaking about the center bore....what purpose does this hole serve other than a place for the center caps to fit? IF the bore is a smaller size can is be opened up with no problems?
Yes it can be opened but but you want the wheel to remain as balanced as possible centrifugally. Some vehicles have smaller hub holes because the axles hubs that extend through the wheels on some trucks(manual lockers) are smaller than others.
ive seen tires like off my old 2000 ranger(15 inch) on a bronco 2 before, so i don't see why they wouldn't work
