babybigfoot
I have a 96 B4000 front end torn down. When I pulled the rotor off of the spindle there was a piece of rubber left on the spindle. Looked like it was up against the seal on the back side of the rotor. It rides on the same surface as the hub seal does but doesn't look like it was connected to the hub seal at all. Looking at a breakdown of a ranger, it looks like a metal piece that in the Haynes manual they call a dust seal. But this dust seal in the book looks like a metal piece. They look nothing alike but they are pretty much in the same place. Is there a difference between the two?
One last question, The spindle seal that is in the back of the spindle where the needle bearing is on mine is a one piece seal with a metal flange that sets inside a plastic ring. When you get a new seal from the parts store they give you a flat rubber O ring and then the plastic ring and a metal cup with a rubber seal going around it. I think this may all tie in together but I am at a lost.
Can anyone explain to me the whole backside of the hub and spindle? Or even better does anyone have a good breakdown of the hub/spindle? Is this the only place that maybe Mazda and Ford differ?
