For not a long time ago I changed Clutch slave cylinder, pilot bearing and the big (first) input bearing on the transmission input shaft (front end repair kit).
Today the transmission started to make a noise in neutral. The noise is also there and when de-accelerating with clutch in/out. Maybe its there all the time the transmission is not clutch engaged in neutral, - can´t tell due to road noise...
I have started to wonder if the input bearing was setup to tight, - and is broken... Any ideas?
