I may be able to get a 2.5 with 5spd for $250.
Its 2.5l 4 cyl engine with tranny5 Spd that came out of a 2000 ford ranger. Has 170k on the engine but is running strong, fresh oil change on it, clutch was redone in July, and is a great motor.
I looked up the specs & all looks better for performance, torgue & fuel economy. How ever the specs show 56-72 psi Fuel pressure for 2000 & 30-40 psi in 1994 is that due to a higher pressure fuel pump in 2000? Would the engine still run fine with the 30-40 psi. Are the injectors different between 94-2000? I would get 19 more HP @ 400 more rpms & 13 more ft lbs @ 400 more rpms.
I should diffently be able to feel the added HP & torque hauling heavy loads & empty ,plus lower .3:1 lower comp better gas milage. I have a 96 Head sitting in storage with a performance cam on it & I have heard that the 96 head has larger valves then a 94 what about any difference between 96-2000 heads.
That cost is what just trannys are going for so I figure its a great deal.
Thanks,For your guys input
