Dave18
Has anyone else had trouble with the OEM clutch master cylinders? I've replaced mine a couple times now. The last one I had seemed to have a valve issue, since I'd get clutch drag even after having the system bled and with no apparent leaks/fluid loss. The new one I put in doesn't do that, but makes a loud squeak and has a lot of "stiction" when you operate the pedal. Not a big deal, but they were both Ford parts and I'd like it to work right!
Is this a problem they fixed eventually? Maybe I could use a later model master cylinder to get around the luck-of-the-draw?
Thanks everyone!
2002 Mazda B3000
Thanks everyone!
2002 Mazda B3000
