thayer1536
- Nov 7, 2014
I have a 94 ranger 4.0 4x2. Ran really rough when started this morning to the point where you couldn't drive it. It felt like you were in too high a gear to start out and it didn't matter how fast or what gear you were in. I let it idle in neutral and it stalled after a couple of minutes. I repeated this several times with the same result. I replaced the fuel filter because I'd been meaning too anyways.
I put a OBD1 reader on it and got code 159-mass airflow sensor out of range. I replaced the sensor this summer to get rid of a check engine light and had no problems. I read that if you unplug the harness while running, the engine should shut off. It didn't when I disconnected this. I'm unsure if this advice is true. I wonder what people would do in my shoes. Try cleaning it, take it back to Autozone and get a new one or could there be another issue I'm overlooking. Feedback welcome.
