2.3L ('83-'97) Mass air flow sensor brands
Chapap
Forum Member
NW Florida
2.3 (4 Cylinder)
Total Drop
1.5” till I get these springs replaced
225-70-R14
Is the MAF something that needs to be a top brand? I have a new one but still have code 159 maf out of range. Every other sensor is new so there *shouldn’t* be anything confusing the computer. I’m pretty sure I have detonation because it seems to not to match any of the descriptions for rod bearings or piston slap.
I would get motorcraft, but it seems none are available.
Edit: I got the Ultra-Power #917834. Second option on RA.
I guess the answer is to get a motorcraft reman. I sent the ultrapower back and got the reman and it runs much better. I hope it actually was reman’d. The aluminum housing and plastic sensor housing look worse than my original. Has lots of corrosion dust that I cleaned off before installing. The security torx heads holding the sensor on are drilled out, so I guess they replaced the guts. Seems to work fine though.
