- Aug 2, 2021
- Merced, CA, USA
- 4.0 V6
- Manual
My 1996 Ford Ranger 4x4 Manual (M5OD-R1) is easy to shift when the car is turned off. However, when the car is running it is very difficult to shift. Sometimes in order to get the car into first, I have to go into reverse, then engage first gear.
I am guessing the problem is in the clutch hydraulic system, probably air in the lines. What do you guys think. Truck has 160k miles on it.
EDIT 2024: TURNS OUT IT WAS THE SLAVE CYLINDER
