gcaiola
I changed the fluid in my 1994 2.3L, MANUAL, 5-speed OD transmission. Either by coincidence, or because of putting new fluid in, a leak began between transmission & transfer case. I can even see that it's deteriorated (can't see gasket between the two metal surfaces), at several places. So it leaks down and I refill as needed (every few weeks). It's run fine for several months this way, but I'm getting tired of it and want to prevent bigger, future problems, and stop dripping fluid everywhere.
In colder weather, it's sometimes hard to get into gear when first starting car, and slightly loud when car is started. Both symptoms appear to be consistent with low fluid levels. Questions:
What's the best solution here? Can I just separate the two transfer case surfaces and use a proper gasket/sealant compound? I'm assuming this is going to be VERY HEAVY once I loosen bolts. Are both sides otherwise supported or when I loosen is the going to be a bigger problem for me to manage?
If I get an actual gasket designed to fit, I'd either have to cut top of gasket (to get around driveshaft) or disasseble shaft (which I'm definitely not going to do).
Any help would be much appreciated!
