mrkartoom
- Jun 21, 2011
Hi new member here looking for some advice. Hopefully this subject has not been beat to death or posted in the wrong section.
The 5-speed manual on my 2002 Ranger 4.0 4x4 was getting very notchy at 168k mi, so I decided to change the fluid to see if that would help. Drained the original and filled it with Mercon V, which I understand replaces Mercon ATF. Before draining I noticed the top and side of the transmission is wet on the outside. I assumed it had a vent and it maybe spewed a bit, but I guess these have no vent. It looks like it is coming from around the the area the shifter enters the top. Regardless ever since I filled it I have been getting a very strong odor from the Mercon V while driving. In fact the cab of my truck smells like it now and I think the odor may be coming up through the floorboard through the shift. Previously it was only sort of intermittent, but now pretty steady.
I never see anything on the ground. Just pulled the fill plug and it it still full to the top. I never had a smell before from the tranny, but the old stuff was not stinky like the Mercon V. Is this a common leak area or problem, and anyone know what is needed to fix it?
Thanks
Thanks
