Chris_1
- Feb 1, 2009
- Automatic
Hi guys, having a problem with the '94 (dana 35) locknuts on the manual hubs.Switched it to manual hubs about 2 1/2 yrs ago.
After adjusting the bearing preload (to specs), we install the lockwasher onto the pin and install the 2nd locknut but can only tighten to about 100 ft lbs - then the inner locknut and locking washer start to turn with the outer. It seems like the locknut is fitting itself into the threads and turning with the outer (everything starts to turn, which won't work because the inners will be way too tight or the outers won't be tight enough).
Inspected the lockwashers, they look perfect, no damage. Bought a brand new Warn set of locknuts and lockwashers - same thing.
Has anyone else encountered this ? What did you do ?
We've thought about (welding) building up the tab on the washer to make it wider or deeper but I'd kind of like to figure out why this is happening _ everything LOOKS to be in perfect condition and this isn't the first time these bearings have been repacked (of course).
So - is this a common thing ? Or have we got some weird kind of problem going on here ?
I would appreciate any input here, as I'm kind of concerned about anyone driving this around with only 100 lbs on the outer locknut.
