Manual Fuel Pump Issues
misak1914
Greetings all. I recently pulled my engine, swapped out a few parts, resealed some gaskets, then put it back in my 84-B2-2.8l. Still haven't been able to start the thing. For one, there's no fuel being pumped into the carburetor. I pulled the metal line going into the fuel filter attached a hose, put the hose in a glass container, turned over the engine, and found there was no gas being pumped. Next, I swapped out the fuel pump because I figured that would be the obvious fix and when I test to see if fuel is being pumped, still nada, nothing, zip.
When I did my search in this forum it seems all I find is advice on 2.9l and newer engines with the fuel cutoff/inertia switch on the passenger's side, under the carpet. Just so that I didn't miss something so simple I actually removed seats and the entire carpet to check. Next, just so I could eliminate the obvious, I jacked up my B2, disconnected my fuel inlet line and put the line in my lawnmower gas tank to see if the pump would draw gas from there. Still nada, nothing, zip.
Can anyone help me figure out why my B2 isn't pumping gas to the carburetor? :bawling: Thanks guys.
If the pump is dry and the line is empty it might take a while to convince it to draw the fuel through. If the line has any damage (pin hole for instance) it will not be able to draw the fuel through. On the odd occasion that mine had a dry fuel line for one reason or another I gave her a good squirt of quick start, which would run the motor for a few seconds and give the pump a chance to prime itself.
when you turn the key to on can you hear the fuel pump? It should run for a few seconds as it primes the carb. Could be a relay problem if you cant hear it or some other wire problem
Hi Swamprat. Not sure what sound a manual fuel pump on a 2.8l makes when I turn the key. Was that a trick question?
But now I don't think it's a fuel pump issue. This time I connected the metal tube to the fuel pump then connected to rubber inlet tube going into the pump, from the pump to a funnel. Filled the funnel with gas and attempted to start the engine. It wasn't all that fast but it did drain the gas from the funnel. Ergo, I must be barking up the wrong tree thinking my issue is with the fuel pump.
Next, to rule out fire to the engine as a problem, I tested the #1 spark plug by pulling the plug attaching the spark plug wire, grounding the plug and attempting to start the engine. Voila! I see the spark. But still no engine turn over.
So, I guess the next thing I can assume is that my B2's timing is jacked up. I'm going to pull the distributor, pull the #1 spark plug, turn the engine until I feel the puff of air, replace everything and try it again. Does this sound like a wise course of action or should I try something else?
before you pull anything apart, give it a shot of quick start down the carb and see if it runs for a few seconds. did you read my previous post?
sorry missed the manual part
I'm with Martin. Go with the starter fluid first. If you can't get the pump to prime after that, then you may have other issues, but it sounds like you have a known fuel delivery issue that needs solved before you move on.
I didn't want to admit it, but my timing was 180 degrees off. Now we're rocking and rolling. Now I just need to locate a timing light and fine tune the timing. I'm not sure how many people come back and say thank you, but if it wasn't for all of the great guys that replied to my various post I wouldn't have had a snowballs chance in hell. Thanks to all who cared to help a stranger. :icon_cheers:
