The Bandit
Is there anyway to make my A/C system on my 1994 2.3 Ranger any colder than it already is? It functions completly fine, but I know there has to be some way to improve it.
don't bother insulating the accumulator because its located AFTER the evaporator and won't improve performance.
Tinting the windows is the best thing to do to help keep cool. And i dont know where your from but on a 95, 100 degrees day there isnt a ac ive ever seen that'll get to 45 degrees in the vent thats 50 below the outside air temp that would be insane maybe on a 80 or 85 day but no higher than that
it sounds like a refrigerant issue, but something that could be causing issues is the flapper on the hot/cold switch, if it is sticking open partially (or closed) you might be getting hot air from the heater section mixing into your cold air conditioned air bringing up the temperature
