- Jan 13, 2009
- natchitoches, la
- Automatic
to make 325 hp w/ turbo load of .65 Brake Specific Fuel Consumption you need 44lb injectors, which the accel ones at summit racing are 64.95 a piece, 389.70 bux altogether. an N/A motor only has BSFC .45 and you could prob get away w/ 30 lb injectors but you cant produce 300 hp w/ an N/A 3.0/3.3 motor weve been over that so im going turbo. on an 8 cylinder motor all you would are 24 lb injectors to make 300 hp but you have 2 extra cylinders, i dont. im just looking for 300 horse and since i cant find 42 lb injectors for a decent price ill up them to 44 lb ones and have the capacity to produce a lil more power and just tune them down and increase my dwell/duration safety margin. the walbro 155lph fuel pump that will sustain 384 hp is 83.95, and i havent called on the maf yet and wont til i go to order it but somewhere in the neighborhood of 300 bux. im not sure if a fuel pressure regulator is needed but i will look into one, i found one for around 150 bux that has the vacuum input on it too. if i could get my hands on a larger fuel rail w/ adjustable regulator i would get one but none are available. you do not need to mod the pcm for high impedence injectors the pcm sends a high impedence signal. a race pcm or standalone uses low impedence signals so it needs low impedence injectors, you CANNOT put low impedence injectors on a stock ecu it will cause problems. since i will be using the megasquirt standalone ill be researching what impedence injector i will need and use the corresponding impedence injectors.
