you pulled the exhaust i assume?
i usually unbolt those 4 bolts in the middle of the radius arm crossmember to allow the two halves to "sag". gives you a few more inches to work with.
Crap, mine sagged upwards.
Even my Toyota 4x4 with 5 speed and dual tcases ALL bolted together is way easier to R&R than this.
4x4rangerguy, which heat shield did you end up cutting and welding on yours?
I just finished a late dinner and will go back out there, unbolt the center crossmember bolts (and the sway bar mounts....lol) and wrestle this thing a lil bit more. Have to at least try to get er in without removing the exhaust....lol.
Wicked_sludge, Thanks for your fast replies! I'm hip deep in the grease and dirt out there in the driveway. Thank God it's not raining yet.
...I pulled the stock FM-146 out of my STOCK bronco II, and put the M5OD in place of it without moving anything related to the exhaust. All I had off was the tranny crossemember. I lowered the back of the motor some, and pulled the shift cover off...
