fred m
- May 31, 2018
- Tallahassee, Florida
- 3.0 V6
- Automatic
I'm considering an M5OD to replace the 5R44E in my '02 3.0 2WD. With 217k on the clock, I'm finally starting to see issues pop up, and since I've been looking for a reason to dump the auto anyways, this seems like the way to go. I've got a buddy with a junk yard, he's got about a dozen Rangers, most of which with 5-speeds. So I'm covered, parts-wise. Wear items like clutch, slave cylinder, and (possibly) flywheel I'll just get off RockAuto.
Now to the questions:
I've heard that there may be different bolt patters between 3.0 cranks in auto/manual trucks. Is this the case? And if so, is there any way to make it work w/o swapping the motor?
I know the starter and computer will have to change.
Anybody know what I'll have do wiring-wise? If the entire trans harness can be replaced, what years will plug straight in? I'm not scared of some custom wiring but with all the computerized crap I'd like to keep electrical mods to a minimum. Anything else I need to know before jumping into this? I want to have everything ready before I tear my truck apart, hopefully keep this as short a job as possible.
