M5od swap flywheel?
92ranger92
Hey guys I bought a 92 4x4 ranger with a 4.0 and a swapped in m5od. From what I have seen I should be able to swap the dust cover and the starter from the 4.0. Will be purchasing a new flywheel, pressure plate, slave, and clutch disc. I am not planning on doing anything crazy as far as the clutch goes but from what I have seen the stock 4.0 clutch is larger and the way to go. Since I'm going with a stock clutch I was just planning on ordering parts for a 92 4.0. While I have it out I will order the shifter bushing rebuild. Just wanted to run this by some guys that have done the swap and see if some might see some issues I may run into. I have both transmissions out now so im just gathering all the parts now
