FORDboy357
- May 9, 2011
- Automatic
1. IIRC, the shifter position in the 97-03 4.2 F-150 is the same as a Ranger's, right? I want to know this because I want to use the R2 behind a 4BT. I don't want to have do a body lift or make a new transmission tunnel to fit a ZF5.
2. Are the 2WD and 4WD transmissions the same other than the tailshaft? Meaning can I take the transfer case, adapter, and midshaft off of any 4WD M5OD and bolt it to a 2WD's case? I'm asking this because I have a buddy who is seriously wanting to convert his 2007 F-150 XL to 4WD but wants to keep his manual transmission. An F-150 4x4's frontend will bolt right on and it will be no sweat to have front and rear driveshafts made. All that is needed is a transfer case.
