m5od help!
fordtech91
1999
Hello I am swapping a 4.0 OHV into a ranger that previously had a 2.3 in it. Its a 97 ranger and I am taking a blown up m50d 4.0 4wd trans and my 2.3 2wd trans and making a trans for my truck for the 4.0 swap. (4.0 2wd trans). So basically the only thing i am using from the 4wd trans is the case so it will bolt to the 4.0. My question is are the input shafts different??? I know the output shafts are different but not sure about the input shaft. I would hold the 2 next to each other but i do not have the internals from the blown up trans anymore.
You will be fine wanting to do what you are doing. Nothing is different between the cases nor the input shafts.
No problem anything else just ask.
Have it all together and everything works/shifts on the bench just had to fool with the shims a little bit at the front. Just waiting for a flywheel and clutch/pressure plate to put it in....
Pretty easy transmissions to disassemble and reassemble. Let us know how it goes.
What engines will the M50D trans with integrated bell bolt up to? I have one for sale and would like to know for listing purposes. Thanks
depends on what it was originally mounted on... there are 4 different versions (2.0/2.3/2.5, 3.0, 2.9/4.0, and duratech 2.3), if it came from a 2.3L or 2.5L Lima truck it'll bolt to a 2.3L, 2.0L, or 2.5L Lima engine, if it came from a 2.9L or 4.0L it will bolt to a 2.8L, 2.9L or 4.0L, if it came from a 3.0L it will only bolt to a 3.0L, and same with the duratech 2.3L version...
you could of used the output shaft from the 4x4 with the 2wd guts and the 4x4 housing and still been able to keep it 4x4
Mine came from a 2.9 Thanks for the info
Are you willing to sell the unused parts from the 4wd version? I have the case and all, I need some of the internals...
Guys start your own threads they will get answered faster. This is you Bruto, Bullfrog and Taragon.
Have any of you searched the forums first?
I'll bet not!
Explorin, You getting jealous that other people posted on this thread? I BET SO!!
I bet you didnt even read my post!! I didnt ask a question, nor offer tech advice, I asked if he wanted to sell a few parts from the blown up trans....
So did I search the forums? Nope. Why would I?
Will I start my own thread? Already did. Its in the "wanted" forum.
Do YOU need to read posts? Yep.
Thanks for playing, better luck next time!!
Wow you really got me on that one and pinponted it oh so close...oh yeah very jealous........YOU have been here long enough to know how to use the PM (private message) function. Send the man a PM! I could care less who posts on this thread, it is highjacking anothers that I'm after. I read your post just fine begging for parts, thank you. Well there you go ...you out did yourself by posting in the wanted forum.....good for you. Maybe you will get some parts off YOUR post.
