Yes, you'll need to remove the top cover, both front and rear bearing retainers
(the rear one after disassembling reverse and 5th).
Final disassembly of the M5OD-R1:
after you have 5th and reverse on the bench.
stand the case on either end and just "jounce it around"
until the straight roller bearings for the countershaft fall off the
shaft and out of the case.
I do it this way because I'm 6'4" and 290lbs and I make it look like I'm shaking a martini (granted a BIG martini, but...)
when you have both roller bearings out you can put the transmission back on the bench because at this point the countershaft will drop down in it's bearing journals and that will allow you to lift the mainshaft up at both ends, rotate the "flats" on the input gear to the top and bottom, pull the input gear forward as you pull the mainshaft back at some point you will be able to tip the front end of the mainshaft UP and tip the input gear to one side and take it out through the front main bearing bore.
Next you tip the mainshaft up (at the front) and slightly towards the drivers side of the case and the mainshaft will slide out of the case.
honestly I do this so quickly that it has taken me several times
as long to type the last two paragraphs than it does to have the mainshaft sitting on the bench and be reaching for the cluster gear to remove it from the case.
In other words, the hard part is disassembling the "japanese puzzle" we call 5th and reverse in the sequence necissary.
Then again I've done it so many times it is as reflexive
as unzipping my pants to pee...
The four NEVERS (four things that people disassemble that they DO NOT need to and doing so only creates problems later)
These FOUR important things to know when disassembling
a mazda M5OD-R1:
1)NEVER remove the reverse idler gear from it's shaft.
Remove the 17mm bolt that holds the shaft to the case and
remove it as an assembly. (when re-installing it use the tailshaft
housing as an alignment guide when torquing the retaining bolt)
2)NEVER remove the rev-5th shift fork from it's shaft remove
the UNIQUE bolt that holds the shaft in the case and remove
the fork, shaft and internal detent as an assembly.
3)NEVER remove the big TORX nut from the rev-5th bellcrank pivot
Remove the Circlip inside the case and while holding the bellcrank
and washer in one hand pull the shaft, nut and retaining plate out
the the case, Reassemble these pieces immediatly to keep from
losing the pieces.
4)NEVER mix and match 5th-rev parts from two transmissions
unless you KNOW how to identify the four distinct variations
in these parts which create compatibility issues that will make
you consider self-commitment to a mental institution.
Someone may want to break this post into two parts:
the first being "final disassembly of the M5OD"
And the second being "four NEVERS of M5OD-R1 disassembly"
as Mini articles.
Just remember who wrote it!
AD
