fix_or_repair_daily
Hi, I'm trying to use a '90 or so 2wd M50D trans with an '86 Merkur 2.3 turbo engine. My question is the engine has a steel oil pan, but the original engine bolted the the M50D had an aluminum oil pan that bolted to the bellhousing part of the trans. I went back to the jyard and got the aluminum pan and it won't work with the engine because the gasket setup is way different. My question is, what should I do? Should I just bolt it together and not worry about where it bolted to the oil pan? Let me know what you guys think.
Thanks,
Josh
Thanks,
Josh
