I saw the article in the tech library and checked mine, since I couldn't pinpoint the slight leak. There isn't any noticeable ATF, but the whole top of the trans is covered in that nice oily dirt indicative of a slow leak, also the plugs are covered in it. I'd like to try the RTV sealant fix tomorrow. Has anyone done this from the cab instead of underneath? Seems like there's more room up top.
Also my T-case seems to have an oil seal leak from the rear out-put. There's a drip on the case there and a spray pattern above it. Otherwise I can't find a leak, and the front out-put is all clean and dry. Does this sound correct of the oil seal failure?
Haynes says basically pull the driveshaft and there is a 30mm nut in the flange, accessible with a thin-wall socket. Anyone have experience with this? Then the seal is right behind it and can be pulled with a screwdriver and new one put back in.
