M50D clutch slave
Hello to all,
Finished converting my m50d from 2wd to 4wd for my bronco11, but
i need to know if anyone knows what size bolts bolt the clutch
slave to the front retainer. I don't know because I started with
a blown fm145 which uses no bolts.
Thanks for any input
Gunmetalbronco2
8mm X 1.25 metric threaded bolts.
choose bolts that are long enough when you stick them through the loose slave about half an inch of "extra bolt" sticks through.
the original bolts were around 25mm long for the "aluminum" slave cylinder
used from 1988-92, for the 1993-2002 (or even later) "plastic slave "
are about 35mm long
AD
Thanks Allan,
You are a true wealth of knowledge with these vehicles
Gunmetalbronco2
