M50 fill plug
Bogus123
Hello, bought a 89 ranger recently with a M50 Mazda trans in it I went to check the fluid, there is a larger 17mm bolt/ plug on the passenger side that pulled out, fluid gushed so I put it right back in, was this the wrong plug by any chance? Thanks
Yes you've got the wrong plug, both plugs are on the drivers side and you use a 15/16" wrench or socket to remove them.
I think it's 24mm plugs on the M5OD, but yeah, look on the driverside. They are marked "FILL" and "DRAIN".
.....i dont remember any plugs on the pass side, unfortunatly im in alaska and cant look haha......but yea drivers says fill and drain....
Plug on the passenger side?
